IFC - Industry Foundation Classes
IFC (Industry Foundation Classes), is an Open Data schema and set of formats used to store OpenBIM data. It is developed and maintained by BuildingSMART International buildingSMART. IFC data can digitally describe many concepts, including:
- Quantification of elements
IFC versions
IFC formats
.ifc
and .ifczip
sees common usage.
IFC classes
, IfcBuilding
, and IfcTask
can have a Name
class has a Representation
attribute.
